Lol. hehehe. I look, but I don't touch!!
Look, curiosity!!, I'm giving you a series of screenshots of the debugger, in case you see something "strange", you who have an expert eye on ARAS, :)
ARAS has given the id, the full file name is in the variable, but when trying to upload it to the server, it fails. Enter an infinite loop.
I tried to copy that same file to the server with the explorer and without problem.
Thanks!!
I agree with Angela. You've most likely exceeded the max path length limit 260 chars. What the path to vault on your server? If something like "C:\Program Files (x86)\Aras\Innovator\VaultServer\Vault\InnovatorSolutions", the path length for vaulted file without filename will be exactly 110 symbols. So you have only 150 for file name.
- team_aras_meupe_com2 years agoCreator III
Thanks to both of you for answering.
Yes, that's what I thought too, but I've checked where the program's Vault is and it's almost in D: root.
I'm leaving it, that path leads nowhere.
It's a bummer, since I had done an action in which the user dumped a bunch of files on the "Document" screen and the system was in charge of creating a document for each line of document uploaded. It was like telling him of all these documents, create an individual document for each one.
It will be necessary to convert the method to C# and try to rename the files when the user uploads them, to automate the process. But I don't know very well how to do it, since when the user drags and drops in the grid, the system fills in 2 fields "Related file" and "name", but I don't actually know where the file is at that moment, in the limbo?, on the user's computer?, in ARAS?.
As far as I know, when it will be saved is when ARAS uploads it to the server.Well, thank you very much to both of you, and sorry for the bricks, hahaha
- Radoslav2 years agoIdeator II
Hello I would suggest that from the Front-End you could shorten the name or inform the user if the file name exceeds a specific limit. If you insist on modifying any data from the back-end you can create a method body and pass it from the front end to the backend with inn.applyMethod("[methodName]", "[methodBody]")
