I keep getting an error with my AML code.
<Item type="MIN_DCP" action="get"
select="id(item_number)">
<system condition="in">(select id from innovator.MIN_SYSTEM where customer = 'F7783E44C97442EDB36...
Hi didonato,
There should be a file in that folder named ItemAnalysis.Suppressions.Example.xml that has some examples to guide you. If that doesn't help, Aras Support ([email protected]) may have some documentation or additional samples to help you out.
Eli
Eli Donahue
