Alexis_Amirtharaj
8 years agoIdeator III
Thank you for your quick reply with solutions in this context. While I will take a closer look into your suggestions, I would also like to add more clarity to my query. I am not trying to create a list for the dropdown box. I am using the dropdown box with the field type of 'item' which allows me to pick an item and assign it to the same field.
For example, let's say I have the following items on a grid with four columns (Name of the attribute, Value as a string value, Data type, Data source if applicable)
'A' <value> 'item' 'user'
'B' <value> 'string'
'C' <value> 'item' 'order'
So, when the user selects 'Show instance' on Row A, the form would have a dropdown box of type 'item' and data source 'user' (which is an item type).
And when the user selects 'Show instance' on Row C, the form would have a dropdown box of type 'item' and data source 'order' (which is an item type).
Many thanks for your support.
Alexis.
