Gopikrishnan's avatar
Gopikrishnan
Accelerator II
Dynamic Drop Down List in Relationship Property
Hi Team
I have below set of code to set the dynamic drop down list in relationship property. It is working in ARAS 12 SP2 version but it is not working in ARAS 12 SP18 version. Can you please let me know what am I missing or what is changed between this two versions
gridApplet.cells(relationshipID,targetColumnIndex).setEditType(2); // This line is through below error
var cell = gridApplet.cells(relationshipID,colNumber);
gridApplet.columns_Experimental.set( cell.grid_Experimental.layout.cells[cell.indexColumn_Experimental].field, "comboList", listArray, valueArray);
Error Message
oneditstart handler failed with message: TypeError: Cannot read properties of undefined (reading 'field')
  • Suppose there is a client having more than one site, so we will create one table for the client information and another table with Foreign Key relationship to store the multiple site information because one client can contribute or write articles on the multiple portals.
  • Do you have an official feedback from support?
    "TypeError" messages are super typical for 12SP18. Have seen similar error messages many times. In the newer Innovator versions Aras has real trouble with federated/poly-like properties which are filled on-demand by code. Big fun!
    Possible solution: Remove the a target property of your Method in the ItemType and then add it again
    If you are an subscriber: Ask for SI-031239 for a possible codetree solution, but it didn´t resolve the root cause. But it´s helpful when other people report similar issues.
    In addition: Where did you find "setEditType" thing? Is your code based on a community project? According to my collection of useful stuff it´s outdated since 10SP4. Not sure, but this is a replacement I found:
    //Since 10 SP4 : Change the way to bind a comboBox on a cell
    var field = gridApplet.columns_Experimental.get(colNumber, "name");
    gridApplet.columns_Experimental.set(field, "editType", "FilterComboBox");
    gridApplet.columns_Experimental.set(field, "comboList", listOfValues, listOfLabels);
        I myself use a relationship dropdown filled by an 'onEditStart' Method and it works pretty normal in 12SP18 with above code. I don´t use the .setEditType(2); code line.
        Maybe add more safety features? I do a check on the colNumber (shall not be invalid) and a if (!gridApplet) { return; }
        But as mentioned before, could be a general SP18 issue. Have you tried to remove and add your target property used for the dropdown?
        Otherwise: Ask Aras [emoticon:c4563cd7d5574777a71c318021cbbcc8] .
  • I also encountered this problem,I think you can replace the relationship property's data type list with item,then you can control the searchDialog content which you want to show.
