5 years agoCatalyst II
Group boxes are a bit evil in their behavior.
As far as I remember, the field order has some influence. When you have added your dropdown after all other fields, it may have a very high field order value. Try to change it to a value between your "Tolerance" fields.
- lucas5 years agoCreator II
the order value for the drop downs are between the other two field's orders. if i put it first or last i get the fields on two lines, it seems like it has some line break properties anyway i think i'm gonna go with vertical fields
