philn's avatar
philn
Ideator II
Disabling field in relationship
Hi all, I am currently trying to disable a field on the relationshiptab when the item is at a certain state. The method is current run under onFormPopulated. Below is my code: ///////////////...
  • carstenw's avatar
    Hi philn,
    I faced the same challenge as you in the following scenario:
    We have a custom item type Part Request with a relationship to a Manufacturer Part. Unless the Part Request is in the LC state 'Awaiting AML Approval' the field is_approved on the relationship cannot be edited.
    I looked to the Programmer's Guide pp. 63-64 and found inspiration for the following:
    This client method needs to be placed on the Property is_approved. Pro tip: This item type can only be locked when the parent item type (Part Request in my scenario) is locked first. Once the Property is locked, add a new client method with the Event OnEditStart with the following content:
    var inn = this.Innovator();
    var relationship = inn.newItem('PartRequest ManufacturerPart', 'get');
    relationship.setProperty('id', relationshipID);
    relationship = relationship.apply();
    var prq = inn.newItem('Kam_PartRequest', 'get');
    prq.setProperty('id', relationship.getProperty('source_id'));
    prq = prq.apply();
    var prqState = prq.getProperty('state');
    if(prqState === 'Awaiting AML Approval') {
    return;
    var cellValue = gridApplet.GetCellValue(relationshipID, colNumber);
    if(cellValue !== '') {
    return false;
    Hope this helps;
    Small note:
    The magic arguments relationshipID and colNumber along with gridApplet is given by the anonymous method containing your method code, like so
    (function anonymous(relationshipID,relatedID,propertyName,colNumber,gridApplet
    debugger;
