Nilesh
5 years agoCreator I
Disabling "Create New Item" Button.
Hello All,
Is there any way to remove or disable the create new item button from UI.
My use case is, I am creating items from the backend code using IOM api and want to restrict Item creation from UI.
For disabling button I can remove can add from item but in that case I can't create items using IOM api as well.
Need some other way remove or disable create button from UI only. Someone please help.
Thanks,
Nilesh
