little_legend's avatar
little_legend
3 years ago
Disable sorting in relationship grid
Hello community,
Does anybody know if it's possible to disable the sorting of a few columns in a relationship grid?
My guess is that the change should be done somewhere in the CodeTree, but I'm not sure where.
Thank you in advance.
  • Have you checked the "Order By" settings of the affected Properties in the ItemType definition? Just remove the Order By value should exclude the sorting for the affected columns.
    Edit: If you don´t see any "Order By" values, check if you have Server Method that is used for sorting. That´s a common trick to achieve descending sorting...
    • little_legend's avatar
      little_legend
      Hello Angela,
      None of the columns have an "Order By" value. I checked also for a method which sorts/disables sort but I didn't find any.
        If you have a regular relationship, check the related ItemType AND the relationship ItemType for any settings regarding sorting.
        If a custom sorting is present, you normally see it due to the arrow in the header column.
        If you don´t have this one -> by default Aras sorts by id (or native sorting in sql database), which can lead to mixed up data by default.
Recent Discussions
