Different Sequence Number for different Classification
Hi Team,
I have a scenario where in I need to generate different document sequence number - for Document Number field based on classification.
Ex : Class structure - Subtype - Class A - AXXX0001, Subtype - Class B - BXXX0001, Subtype - Class C - CXXX0001 - All these classification have different form configured and each form has Document Number field. Accordingly created respective custom properties with datatype - sequence and added datasource.
Is it possible to achieve generating sequence number without custom code? Kindly suggest. I am facing issue with configuration - while saving document, it shows all sequence numbers concatenated at header as 'Keyed_Name' which is not valid.
I am able to generate different sequence number based on classification by custom code added under server events - OnBeforeAdd.
Thanks,
Sowmya
