BerntOve's avatar
BerntOve
Deleting Part BOM relationships on Parts
I`m currently trying to develop a function that easily deletes all Part BOM lines of a specific type (in our configuration "Purchased Parts"). All assebly parts should be left alone since in my next part of development my plan is to run the method also on these (i.e. make it recursive).
I have made an action on the Part Item that runs the following code:
Item qryItm = inn.newItem("Part", "get");
Item PartBOM_Relationship = inn.newItem("Part BOM", "get");
Item BOM_Part = inn.newItem("Part", "get");
qryItm.setID(this.getID());
PartBOM_Relationship.setRelatedItem(BOM_Part);
qryItm.addRelationship(PartBOM_Relationship);
Item partItm = qryItm.apply();
partItm.setAction("edit");
Item partRelationships = partItm.getRelationships("Part BOM");
for (int i=0; i< partRelationships.getItemCount(); i++) {
       Item part_relationship = partRelationships.getItemByIndex(i);
       Item partItem = part_relationship.getRelatedItem();
       if (partItem.getProperty("ve_classification_display", "") == "PURCHASED PART") {
             partItm.removeRelationship(part_relationship);
partItm = partItm.apply();
return partItm;
I have checked that the if is triggered and a new generation of the part is generated, but the Part BOM relationships are still there in the new generation of the part.
I have also tried to delete the relationship item but this is not allowed in my current configuration.
What am i missing?
  • Hi BerntOve
    You can use below method to delete the Part BOM with classification "Purchased Part"
    PartBOM_Relationship.setProperty("source_id", this.getID());
    PartBOM_Relationship.setAttribute("select", "id");
    BOM_Part.setProperty("ve_classification_display", "PURCHASED PART");
    BOM_Part.setAttribute("select", "id");
    PartBOM_Relationship = PartBOM_Relationship.apply();
    List<String> idLists = new List<String>();
    for (int i = 0; i< PartBOM_Relationship.getItemCount(); i++)
    idLists.Add(PartBOM_Relationship.getItemByIndex(i).getID());
    if(idLists.Any())
    Item PartBOM_Delete = inn.newItem("Part BOM", "delete");
    PartBOM_Delete.setAttribute("idlist", String.Join(",", idLists));
    PartBOM_Delete = PartBOM_Delete.apply();
    if(PartBOM_Delete.isError())
    return inn.newError("Error Deleting the Part BOM relationship");
    return this;
    Thank You
    Gopikrishnan R
    • BerntOve's avatar
      BerntOve
      Hi Gopikrishnan,
      Thanks for the reply. Unfortunately I`m not able to delete the Part BOM relationship item as in your example. I get the nice error "Not a single item" as the error message. Even if i expose the Part BOM itemtype in Innovator TOC and try to delete it form there i get the same message. Its a bit strange since i am an administrator and the item permission states uses the source access that states i should be able to detele the item.
      When i manually remove a Part BOM item for a Part i see that the Part BOM relationship exists still on the previsous generation of the part. The Part ItemType is of course under revision control and its possible that in my case blocks me from deleting them.
      I have also tried deleting the relationship item from AML studio as the Innovator Admin and its still the same.
      Bernt Ove
      • Gopikrishnan's avatar
        Gopikrishnan
        Accelerator II
        Hi
        Can you check in the Part BOM item type any method is triggered in Server Events tab On After Delete / On Before Delete events ?
