9 years agoAccelerator III
The Aras AML schema is documented in the "XSLT Report Tool Users Guide" on page 19. I've extracted it from the document and pasted it below:
<xsd:schema xmlns:xsd="">www.w3.org/.../XMLSchema">
<xsd:complexType name="Item">
<xsd:all>
<!-- Any user elements defined by the ItemType for the item -->
<xsd:complexType name="Relationships" minOccurs="0" maxOccurs="1">
<xsd:all>
<xsd:element name="Item" minOccurs="0" maxOccurs="unbounded">
<xsd:complexType>
<xsd:all>
<xsd:attribute name="id" type="xsd:ID" />
<xsd:attribute name="type" type="xsd:string" />
<xsd:attribute name="typeID" type="xsd:IDREF" />
<xsd:attribute name="action" type="xsd:string" />
<xsd:attribute name="sort_order" type="xsd:integer" />
</xsd:all>
</xsd:complexType>
</xsd:element>
</xsd:all>
</xsd:complexType>
</xsd:all>
<xsd:attribute name="select" type="xsd:string" />
<xsd:attribute name="order_by" type="xsd:integer" />
<xsd:union>
<xsd:attributeGroup>
<xsd:attribute name="pagesize" type="xsd:integer" />
<xsd:attribute name="page" type="xsd:integer" />
</xsd:attributeGroup>
<xsd:attribute name="levels" type="xsd:integer" />
<xsd:attribute name="config_path" type="xsd:string" />
</xsd:union>
</xsd:complexType>
</xsd:schema>
