9 years agoAccelerator III
Hi Eli ,
Thanks for reply . As you mentioned above I have used the SOAP request to send the request to server . And I got the response in the form of SOAP message . But I cannot always use that XML format for further processing . I want that response to be stored in some java objects so that I can use it easily . So I searched for it and I found that Jaxb can convert a schema to its equivalent java classes but there was no fixed schema definition for AML . So is there any way so that I can get AML schema from server or some method to convert that response to its java objects ?
Thanks for help !
Ketan .
