8 years agoAccelerator III
Thank you Chris, finally you pointed out the problem. It works perfectly. My Questions are :
- If Suppose I click Save while creating a new Document, this method is getting called and it gets a new sequence number but it's lost
- Say I create Document and onAfterAdd method is called and the sequence is also called but the document is not added. Again when I click save and close , a new sequence number is called .
