8 years ago
Create CAD Document using IOM API
Hi, How can I create and attach file with a  CAD Document through IOM API? Here is the code I am trying to implement. <hr /> // Create the CAd Document item var docItem = MyInnovator.newItem("CAD", "add"); docItem.setProperty("item_number", "CADDoc 004"); // Create the File item and set the path to the file. var fileItem = MyInnovator.newItem("File", "add"); fileItem.setProperty("filename", "My Document.docx"); fileItem.attachPhysicalFile("D:\\My Document.docx"); // Create the relationship between the CAd Document and File var relItem = MyInnovator.newItem("CADFiles", "add"); docItem.addRelationship(relItem); relItem.setRelatedItem(fileItem); var results = docItem.apply(); <hr /> I guess CAD files are null able type of relation since there is null value in related id column in CADFiles table...
  • Hello, It appears that the CADFiles relationship is unique in that it is not a relationship between the CAD and File itemtypes. Rather, it is a null relationship with a file property called "attached_file". I have updated the sample Method you provided to account for this. Additionally, I have updated your sample to use the newer setFileProperty function that is in 11.0 SP9.
    relItem.setFileProperty("attached_file", @"C:\Temp\Test.txt");
    If you are using a version of Innovator before 11.0 SP9, you will need to rewrite this sample to use the attachPhysicalFile function that you were using initially. Chris ______________________________________ Christopher Gillis Aras Labs Software Engineer
    • anhht-hue's avatar
      anhht-hue
      Hi Chris,
      Pls help me to how can I create CAD Document Item with file is attached to native File. (I using Aras 11.0 SP15)
      Thanks so much.
    • Former_Member's avatar
      Thank Chris, after Iam using your example, i get error from server: "add access is denied for CAD"
      What do you know about my problem?
      Thank Chris!
      • christopher_gillis's avatar
        This is really a separate question to the one that was originally asked, so I'll ask that you make a new forum post to ask it. Doing so helps maximize the visibility of your question to our entire community, and it also helps people find the answer if they have the same question in the future.
        Thank you.
