angela's avatar
Comments after return in Client Method leads to 'event handler' error
Hi community, I discovered a strange behavior in Innovator 12.  Let´s assume we have a regular Form with a button that uses the following onClick event: alert("This is just a test button eve...
  • Hi Angela,
    Thanks for pointing this out. I was able to reproduce this in my local instance of 12.0 SP1 and SP3. It seems this is caused in the code that's responsible for building the actual HTML events in the form. When the event is built, the method code is inserted into an anonymous function with code similar to the line below:
    "function() {" + the_method_code + "}";
    When the final line of the method is a comment, it seems it's also commenting out that closing bracket of the anonymous function which is causing the error you're seeing.
    I've filed a ticket for this issue. In the meantime, you can workaround this by either not using comments on the last line of your Field Events or by adding an extra newline to the end of your function. However, I wouldn't count this as a "design rule" exactly since this workaround only seems to be necessary for Field Events specifically. I also tested the same method code in an onLoad Form Event as well as a Client Action and both of those worked as expected.
    Aras Labs Software Engineering
