Former Member
5 years agoNot applicable
Because the structure of the Color class in WPF supports both approaches.Use either standard RGB properties set (A, R, G, and B) and a set of scRGB properties (ScA, ScR, ScG, and ScB). These properties are related, so if you set the R property, then the ScR property will change accordingly. This is how the color changes.
https://writemyessay.onl/write-my-assignment/
