Hi Suhas,
happy new year! You probably already solved the issue, but I want to answer anyway. The problem can be solved by adding a assembly binding in one of the web.config files.
- Suhas3 years agoCreator III
Hello Angelalp,
In which web.config i need to add assembly binding? & how to add it?
Regards,
Suhas
Hi Suhas,
I probably was wrong. Your PublicKeyToken doesn´t match the error message you typically get when assembly binding is missing.
You have to add assembly binding in Innovator/Server/web.config when you use DLLs that use the IOM.dll. This file is typically overwritten when using a update patch. But your dll doesn´t use IOM.dll.
How did you add your dll? Have you modified method-config.xml?
Edit: Do you have a backup of you previous codetree? Maybe check if the various web.config already contains something for the dll.
Hello AngelaIp,
I didn't modified any aras dll (IOM.dll) or web.config file. Just I have added closedxml.dll file in bin folder & added namespaces in method config file with file path.(How we are using external ddl in aras in same way). Same dll is working for Aras12SP9.
The major difference which I noticed is in Aras12SP9 "WindowsBase.dll" is present in server bin folder whereas in Aras12SP22 it is missing. I have copied the same dll in bin folder but then also it is not working.
Regards,
Suhas
