Yoann_Maingon
9 years agoAccelerator I
I would suggest in a client method that you check if the item is locked.
If it is unlocked, after form is populated, you replace the input text field by a "a" tag with your value inside and also as an "href" attribute.
it will only work on forms, not in grids.
