Kara's avatar
Kara
Class Structure(Classification) Field onChange Event
Hi Everybody, I am want to write a code 'on Change" Event of Classification Property to set one of the drop down field value. I am not getting success to getProperty Value of Class Structure Prop...
  • cogres's avatar
    Hi Kara,
    in the onChange method, you can use
    var classi = getFieldByName("classification").getElementsByTagName("input")[0].value;
    And then switch over classi to set the dropdown value depending on your business logic with
    window.handleItemChange("list_property", "value you want to set");
    Is this what you need?
    Cheers,
    C
