Hi Suhas ,
I tested this on R31 and saw the same behavior Angela described. Do you perhaps have other customizations in the code tree?
Yes eli_donahue , We have to modified code files for same.
In templates.tsx we need to do below changes
code addition: line 218-line 234
In tgvViewer.min.css file we need to do below changes:
I hope it will work.
Please let me know in case of anything.
- angela1 year agoCatalyst II
Hi Suhas,
many thanks for the update on this one! Which Innovator version did you use for your tests? It´s definitely an I14. But is it something higher than Release 30?
- Suhas1 year agoCreator III
Hello angela,
I have checked for Aras 24 & 28 versions & it is working fine for both versions.Regards,
Suhas
Thanks for the hint! I didn´t find the "cellProps" variable in Release 2023.
But it´s available in Release 26. It should also work in Release 35. There are few changes in the file, but they shouldn´t affect your code.
Colored TGVs would be really helpful! I will give it a try next week.
