angela's avatar
Change style of default Form button (without using a full custom html button)
Hi community, has anybody some experience with customizing the standard blue form buttons in Innovator? I want to make them not blue fixed size independent from button label round corners...
  • cogres's avatar
    Hi Angela,
    I have used the following before, so maybe it will help you, too.
    The background colour can simply be picked under the "Field Type" tab when editing the form:
    Under the "Form Body" tab, you can then insert some CSS for input elements that are buttons:
    Then button then looks like this:
    The "border-radius" makes the corners round, since that was one of your requirements.
    Hope this helps,
    C
