8 years agoCommunity Manager
Hi ahmed,
You can do this by modifying the Workflow Map. When you select a workflow activity in the map, you can configure the promotion you want to occur under the Promotions tab. In order to promote your item to the "in progress" state, you'll want to add a new promotion event and configure the columns as shown below.
- Event - You'll likely want to choose 'On Activate' which will occur when the workflow gets to your chosen activity
- ItemType - The ItemType you have attached your life cycle to
- Life Cycle - The Life Cycle Map you have created
- From State - The Created state of your Life Cycle
- To State - The In Progress state of your Life Cycle
- Role - The Identity that will be performing this promotion (Aras PLM is the standard Role for these kinds of automatic promotions)
