eli_donahue
8 years agoCommunity Manager
Hi Ahmed,
Since the method doesn't update the context item, you'll need to update it with your code. For example:
partItem= partItem.promote("in Bearbeitung","Promoted");
Note that this is replacing partItem with the result received from the server, so any previous changes to that item that were not applied to the server may be overwritten in memory.
Eli
