8 years agoAccelerator III
Hi , Thank you for your answer .
but how can i do it manual .
i created method with this code :
var innovator = new Innovator();
var t5id = getFieldByName("text0").getElementsByTagName("input")[0].value;
var t5date = getFieldByName("text1").getElementsByTagName("input")[0].value;
var t5name = getFieldByName("text2").getElementsByTagName("input")[0].value;
var t5comment = getFieldByName("text3").getElementsByTagName("input")[0].value;
var t5button = getFieldByName("Update").getElementsByTagName("input")[0].value;
var partItem = innovator.newItem("result4","update");
var id = document.thisItem.getProperty("id");
partItem.setID(id);
partItem.setProperty("t4id", t5id);
partItem.setProperty("t4date", t5date);
partItem.setProperty("t4name", t5name);
partItem.setProperty("t4comment", t5comment);
partItem.apply();
I want, if the button is pressed, the status should be changed
