9 years ago
Change Sort order of property on relationship?
I have created a relationship between ItemType A and B. However, I also want to add an additional property on the relationship ItemType. I open up the Relationship ItemType and add a new property. I also set the Sort Order of this property. But this new added property will always turn up to the far right on the Relationship tab. The related ItemType properties will be shown before my new Property. Any suggestions how to achieve this?
  • You can control the column order of a grid with the Grid View property of the RelationshipType item (not to be confused with the RelationshipType ItemType). Setting the Grid View property to Intermix should sort all of the columns of the parent, source, and relationship based on the Sort Order property. Dennis
