Thanks Christopher, your advice put me in the right track. Between out IT department and myself we sorted it out.
For other people with the same limited ICT skills as myself, my IT guy explained it as such:
(It should probably be classified as a "Lie-to-children" explanation, but it makes sense to me)
When you run a C# method on the server, Aras is following the URL. With the new URL it was going out of the server and trying to find it on the internet, our firewall blocked the script from coming into the server again. So he defined the URL on the local host file......now everything is working.
Regards
Riaan
I face a similar issue when using attachPhysicalFile for uploading a file to the server. I use a REST call to upload text content that than shall be converted to a file by Method. The Method works fine when directly started within Innovator. But when I call it from REST I get the exact same error. Do you have more information about "how to define URL on a local host file"? Would be happy about any additional help :)
