corbin_mccumber_donaldson_com's avatar
9 months ago
Batch Delete Identity Memberships
Hello, We have used the batchloader utility to create new memberships in Innovator. It appears that removals are a bit more difficult due to safeguards in place for the system. What is an easy path ...
  • MaksymArchybasov's avatar
    9 months ago
    Hi Corbin,
    I've recently had a task to synchronize identitiy assignments between two environments. Unfortunately I haven't found the easier way than to write a simple script (basically it was a .net console app).  Here is the classes I've written.
    using Aras.IOM;
    namespace PLM_Utilities.Identities
        public class Identity
            public string Id { get; private set; }
            public string KeyedName { get; private set; }
            public List<Member> Members { get; private set; } = new List<Member>();
            // Constructor that builds Identity object from AML item
            public Identity(Item identityItem, Innovator inn)
                Id = identityItem.getID();
                KeyedName = identityItem.getProperty("keyed_name");
                LoadMembers(identityItem);
            private void LoadMembers(Item identityItem)
                var members = identityItem.getRelationships();
                for (int j = 0; j < members.getItemCount(); j++)
                    var memRelItem = members.getItemByIndex(j);
                    var memberItem = memRelItem.getRelatedItem();
                    var member = new Member
                        RelationID = memRelItem.getID(),
                        Id = memberItem.getID(),
                        KeyedName = memberItem.getProperty("keyed_name")
                    Members.Add(member);
            public bool SyncMemberWithOtherIdentity(Innovator inn, Identity identity)
                foreach (var member in Members)
                    RemoveMember(inn, member.RelationID);
                foreach (var member in identity.Members)
                    AddMember(inn, Id, member.KeyedName);
                return true;
            private void RemoveMember(Innovator inn, string memberId)
                var aml = $@"<AML><Item type='Member' id='{memberId}' action='delete'/></AML>";
                inn.applyAML(aml);
            private void AddMember(Innovator inn, string identityId, string memberName)
                Console.WriteLine(memberName);
                var aml = $@"<AML><Item type='Member' action='add'>
                            <source_id>{identityId}</source_id>
                            <related_id>
                                <Item type='Identity' action='get'>
                                    <keyed_name>{System.Security.SecurityElement.Escape(memberName)}</keyed_name>
                                </Item>
                            </related_id>
                         </Item></AML>";
                inn.applyAML(aml);
        public class Member
            public string Id { get; set; }
            public string RelationID { get; set; }
            public string KeyedName { get; set; }
    Hopefully it will help you to get the idea
    Best regards, Maksym Archybasov
