R_'s avatar
R_
9 years ago
Avoid Creation of relatonship depending upon condition
hiii i want to avoid creation of relationship depending upon condition that same item cannot be added in relationship i write code to find same item but not able to avoid adding selected item in relationship i put code on onInsertRow event of relationship grid
var rowId = gridApplet.getSelectedId();
var rid=relatedID;
alert(rid);
alert(relationshipID);
var thisItem1 = parent.thisItem;
innovator = parent.thisItem.getInnovator();
var bid=thisItem1.getProperty("id");
var imnf=innovator.newItem("bal_batch2process","get");
imnf.setProperty("related_id",rid);
imnf.setProperty("source_id",bid);
var res=imnf.apply();
var mnfCnt=res.getItemCount();
if(mnfCnt!==0)
  alert("Mnf Process used already");
  gridApplet.deleteRow(relationshipID);
  var no=gridApplet.getRowsNum();
  alert(no);
  var gid=gridApplet.getRowId(no+1);
  alert(gid);
  gridApplet.deleteRow(gid);
  //gridApplet.deleteSelectedItem();
  // gridApplet.removeAllRows();
  return this;
  • Can you tell us what happens if you do a step by step debug? That's where you might see what isn't right.
  • R_'s avatar
    R_
    upto alert() statement it works fine but it not delete item from relationship
  • It seems like you just look at alert messages to debug. I suggest you look in the console what happens.
