eli_donahue
8 years agoCommunity Manager
Hi djjerme,
You can use the console upgrade utility for importing and exporting Aras Innovator packages. It's included in the Package Import Export Utilities download. Here's an excerpt from the doc that includes parameters for the console upgrade utility:
The Console Upgrade Tool is a command line version of both the Export Tool and Import Tool described above. The command line parameters can be obtained by typing ‘/?’ as the command line parameter.
Required Parameters :
server=url server's URL (e.g. server=localhost/InnovatorServer)
database=db database's name (e.g. database=dbWithoutSolution)
login=uname user's login (e.g. login=root)
NOTE: login must have root or admin privileges password=pw user's password (e.g. password=xxxx )
release=rel release's name used by import only (e.g. release=rel11.0)
mfFile=path explicit path to .mf file (Not required for export. Default behavior is “export all”)
Optional Parameters :
import import or export (by default export)
merge used by import only (by default uses non-merge option)
fastmode used by import only (by default uses thorough mode that provides more through verification of the applied AML)
verbose used by import and export (by default uses non-verbose)
dir=d1 export: output directory
import: location of the manifest file
NOTE: the specified path must exist. If the parameter is not specified at all,
user is prompted for the path
log=logpath full path to the log file. If specified file already exists it's appended.
description=desc release description used by import only (e.g description="SolutionsUpgrade")
vlog save the resulting log file on the vault (don't save if the argument wasn't specified)
level=n request attribute 'level' that is used for non-dictionary item types (used by export only)
default: level=1
Hope this helps!
Eli
