Automate download of CAD files to send to Supplier
- 6 years ago
Hi Paul,
The Download Multiple Files community project works by downloading the files a user has selected in the grid, but you can use the same general process for downloading multiple files from a structure.
You can split this into a couple smaller problems.
- Do a recursive call to get all of the items in the CAD Structure
- Get a list of Files that need to be downloaded
- Download all of the Files in the list to the server
The first problem of performing a recursive call can be solved by using the GetItemRepeatConfig action described in this blog post. We use the Part -> Part BOM structure as the example in that blog post, but you can easily rewrite the AML to work with CAD -> CAD Structure.
The second is to get a list of all of the Files that need to be downloaded. You can do this pretty simply by using an XPath selector like //native_file/text() to avoid manually iterating through the entire structure. Depending on your exact AML query, this will get you a list of IDs for the Files that exist in your CAD Structure.
For the last step of downloading all the files, you can look at the Create Zip on Server method of the Download Multiple Files project for some sample code that uses the Aras.IOME.CheckoutManager class to download a collection of File items to a location on the server. You can find a full reference of this class in the API guide available by logging into Aras Innovator as an admin and selecting Admin > API Reference (.NET) in the user menu. Once the files are in a common location on the server, you can package them up however you want to deliver them to the supplier.
