8 years agoAccelerator III
ArasLabs/collab-folders
I am trying to use ArasLabs/collab-folders (github.com/.../collab-folders)
with Aras Innovator Version 11.0 SP11
I have importing all packages including optional successfully. And also copied codetree folder.
And I can sign-in without any issue.
But I get the following error, whenever I try to open folders related views.
Cannot load grid configuration ” ! ERROR: – Failed to get the tgc_Apply to Item Types ItemType.
Issue is coming from \Innovator\Client\Solutions\CommonUtilities\javascript\CommonBaseTreeGridCfgHandler.js
and the following bold line fails. Seems it fails to get configuration item for itemtype.
var configItem = top.aras.newIOMItem(“”);
configItem.loadAML(‘<Item type=”‘+this.applyToItemType+'” action=”CommonBase GetGridConfigItem” configName=”‘+configItemName+'” />’);
configItem = configItem.apply();
if (configItem.isError()) {
top.aras.AlertError(top.aras.getResource(“CommonUtilities”,”commonUtilities.message.cannot_load_grid_configuration”).format(configItemName)+” – “+configItem.getErrorString());
return false;
this.configItem = configItem
Please help with pointers to fix the issue. Thank you so much.
Note: I did not get any answers from Community forum, so asking again in Development forum. I hope that is not a concern.
