Nathan's avatar
Nathan
Creator III
Aras to JIRA Help
Good day all.  I want to connect Aras to JIRA.  I found this article How to integrate JIRA into Aras Innovator with information on how to accomplish this.  I was wondering if anyone has accomplished this?  I have some questions about the ARAS_JIRA_Settings method.
Item JIRA_settings = inn.newItem("JIRA_settings","");
JIRA_settings.setProperty("JIRA_projectkey", "-proj_key-");
JIRA_settings.setProperty("JIRA_token", "-paste-token-here-");
JIRA_settings.setProperty("JIRA_user", "[email protected]");
JIRA_settings.setProperty("JIRA_baseURL", "https://[your-jira-instance]/rest/api/2");
return JIRA_settings;
I found info about the project key.  It is assigned when making the JIRA project.
What token is needed for this?  Where does this come from?
The way this is written, it makes me think that it will be a single e-mail address used for connections  Is this correct?
Thank you for any help you can provide.
  • Hi,
    Token is nothing but access Token which you can generate in Jira, Instead of token you can also Pass Username and password as parameters as shown below
    string username = "xxxxxxxxxxxx";
    string password = "xxxxxxxxxxxxxxxxxxxxxxxx";
    string JIRA_projectkey = "TES";
    string JIRA_baseURL = "">192.168.1.2:9090/.../2";
    string encoded = System.Convert.ToBase64String(System.Text.Encoding.GetEncoding("ISO-8859-1").GetBytes(username+":"+password));
    • Nathan's avatar
      Nathan
      Creator III
      SunilReddy,
      Thank you for the information.  This helps.
