Former_MemberAccelerator III9 years agoAras Server Method Event IdentificationI have an requirement where i am calling the same server method on Server Events On After Update, On After Add and On After Delete. Is there a way i can check from which event the method is called.
Yoann_MaingonAccelerator I9 years agonot sure I understand when you said "I could able to solve this eventdata. GetType()." you found a solution or you which this existed?
Recent DiscussionsBatchLoading Properties that have LF (linefeed) characters in their dataUnofficial Aras Innovator Patch for the Upcoming Browser XSLT Processor Removal (November 2026)How to use explicit xProperties in ItemType?Tree Grid View slow: reads whole branch on expand — improvement ideas?How can I control/track floating behavior of Parts?
