I have an requirement where i am calling the same server method on Server Events On After Update, On After Add and On After Delete. Is there a way i can check from which event the method is called.
Hummm, I don't think you can easily do that. But, you could create a different method for each trigger which calls most of your common code in a generic method. Would that solve the problem?
