Frank_Guarino
12 months agoIdeator I
Aras PDF Styling for Technical Documentation
I've been wanting to use "Publish Document" from the Technical Documentation Item type.
The exported PDF has really large side padding... Is there a way to remove this?
Best ...
- 12 months ago
Answer: By using the HTML output, you can find the correct selectors needed - this is due to both the HTML and PDF output sharing for the most part similar CSS specs
