frank_guarino_murata_com's avatar
2 years ago
Aras PDF Styling for Technical Documentation
Hello, I've been wanting to use "Publish Document" from the Technical Documentation Item type. The exported PDF has really large side padding... Is there a way to remove this? Best ...
  • Answer: By using the HTML output, you can find the correct selectors needed - this is due to both the HTML and PDF output sharing for the most part similar CSS specs
