chernandez1288's avatar
8 years ago
Aras Issues
I’m receiving errors with Ara. IOMLogin.aspx Either IOMLogin.aspx is not setup to use intergrated Windows authentication or the authentication failed. Another user has Enovia, but Aras plugin does not work. I just started at this company and first time being exposed to Ara and Catia. Please help!
  • eli_donahue's avatar
    eli_donahue
    Hi chernandez1288, If you are still having trouble with Innovator and Catia, I recommend contacting Aras Support ([email protected]). They will be able to help you troubleshoot the Windows Authentication configuration. Eli
