Aras 12 - Value cannot be null.
I installed a new version of Aras 12 on a brand new server. I get the following error anytime I try to add something. (ex: create a new part)
Value cannot be null. Parameter name: methodType
-<SOAP-ENV:Envelope>
-<SOAP-ENV:Body>
-<SOAP-ENV:Fault>
<faultcode>SOAP-ENV:Server</faultcode>
<faultstring>Value cannot be null. Parameter name: methodType</faultstring>
-<detail>
<af:legacy_detail>Value cannot be null. Parameter name: methodType</af:legacy_detail>
<af:exception message =" Value cannot be null. Parameter name: methodType " type =" System.ArgumentNullException " />
</detail>
</SOAP-ENV:Fault>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
Good day. Have you looked at the ItemType to see if it is a mandatory field or a specific pattern that is required? It could also be a method that is checking a field for information.
