Suhas
6 years agoCreator III
Hello miraks,
You can removed relationships tab with the help of configuration. So you can use complete screen for Source item.
You can do Tabs Off in "Default Structure View" property on your item type.
Please find the below screenshot to disable relationships tab.
Regards,
Suhas
miraks
Hello Suhas,
Thank you for your answer.
I already have the property on "Tabs Off".
In the "Form" / "Form Properties", if I change the "Height" to 1000 (default value is 234) then the display is better but now I have 2 vertical scrollbars. One for the frame "Costing Context" and one for the main frame.
For me, there is no sens to have a main frame with only one frame. I would like to have the content of the "Costing Context" directly in the main frame (like in R 11).
