8 years agoAccelerator III
Hi Zahar,
Thank you for your answer, however i haven't been able to make your AML resquest works as intended, it always return all the items wheter or not the item's Relationship is empty or not (is null and is not null yield the same result). Even using your exact code on Part and BOM.
Could you tell me if it works on your end, i havent been able to figure out what's wrong on my end.
Thank you again !
Léo
