Jerry,
I have 2 options for you to make your code to work:
- If you know the ID for the item you can use id attribute and not where attribute, so your code will look like:
<Item isNew="1" type="iq Mold Acceptance" action="edit" id='2A4871E1511241E19E300EF92DD5B0C1'>
- If you want to use where attribute, you need to change the way you write it, so the name of the item will be between square brackets and spaces replaced with underline:
<Item isNew="1" type="iq Mold Acceptance" action="edit" where="[iq_Mold_Acceptance].id='2A4871E1511241E19E300EF92DD5B0C1'">
