dkinsley
2 years agoCreator II
AML Coding
I need to find all of the part numbers that have been on a CN that had the part disposition of either "Scrap" or "Repair".
I can find the CN numbers but it doesn't list the affected part part nu...
- 2 years ago
This seems to be a custom change process, so we don´t know your currently used structure. But right now you only get the relationship that links to the Affected Item, but not the Affected Item and the Parts itself.
I assume you have following structure:
a_CN
--> a_CN_Affected_Item
--> Affected Item
--> affected_id --> Part
--> new_item_id --> PartIf you reuse the regular "Affected Items" from Innovator, add an additional query to "Affected Item" and then an additional query to either get the Part connected to "affected_id" or "new_item_id".
It should be enough to add the additional level for Affected Item and then use a advanced select attribute to get the Part level, like select="affected_id(item_number)"
