gteachout's avatar
gteachout
AML code needed to load Requirements Engineer items
I am trying to batch load a series of requirements from another system into Requirement Engineering. I have been able to create a item using the following code.
<AML>
<Item type="re_Requirement" action="add">
<classification>Text</classification>
<global_version>34012</global_version>
<req_complexity>Low</req_complexity>
<req_document_type>8DF7037346A64816B8BBD8700AFCFE15</req_document_type>
<managed_by_id>EA1E67E3DD2340CEA4D49E1670AFBCE0</managed_by_id>
<req_title>Batch load test3</req_title>
<req_priority>Low</req_priority>
<req_risk>Low</req_risk>
</Item>
</AML>
Where it is failing is when I add in the <content> tag information.
<content xml:lang="en">Aras Review
Document Control
11977 and 12666| This goes hand and hand
15964 Aras or Scale?
13207 Does Scale need Legacy classification/Remove</content>
I can see there is other coding tags needed to format the text but do not know how or what coding is needed. Can someone share a example or a process on how to complete this task.
    • gteachout's avatar
      gteachout
      Thanks for the response, here is the error message I receive
      <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
      <SOAP-ENV:Body>
      <SOAP-ENV:Fault xmlns:af="http://www.aras.com/InnovatorFault">
      <faultcode>SOAP-ENV:Server</faultcode>
      <faultstring>
      <![CDATA[Data at the root level is invalid. Line 1, position 1.]]>
      </faultstring>
      <detail>
      <af:legacy_detail>
      </af:legacy_detail>
      <af:exception message="Data at the root level is invalid. Line 1, position 1." type="System.Xml.XmlException"/>
      </detail>
      </SOAP-ENV:Fault>
      </SOAP-ENV:Body>
      </SOAP-ENV:Envelope>
      • Gopikrishnan's avatar
        Gopikrishnan
        Accelerator II
        Hi
        Can you try with below
        <AML>
        <content>Aras Review
        Document Control
        </Item>
        </AML>
        It it doesn't work, try removing special characters in content tags
  • The challenge with using the batch loader for adding Requirements, as part of Requirements Engineering, is that there is an onBeforeAdd server method that generates the data for the <content>...</content> property. The data for the <content>...</content> is taken from the <item_number> and <req_title> properties.
    So the <contents>...</contents> property seems to be overwritten by the server event, thus not considering any inputs from the batch loader.
    A small change to the onBeforeAdd method could allow further fields to be added to the Requirement - a Description field for example.
    But I do not have the experience to update this method.
    Further investigation has identified a high-risk method of automatically adding a 'Title' and 'Text' elements to a already defined re_Requirement. Use SQL (via applySQL or SQL Server Management Studio).
    The <content>...</content> from an existing pro-forma requirement can be inserted into an existing re_Requirement table record. The results present, and are editable.
    For example,
    1. Create a pro-forma template of the re_Requirement manually. With the addition of a Title block and a Text block, the database record is
    <Requirement aras:id="06915ffbc3bd4f3a9f341b16e94857d1" reqId="696D862F9799459D987B3D63D86FC249" xmlns:aras="">http://aras.com/ArasTechDoc" xmlns="">www.aras.com/REStandard"><Requirement-Info aras:id="a8b2b599b8244e738845a2272e0f2176"><Requirement-Chapter aras:id="5a7f493f2f504bd39b3ddf6b20500bbf"><aras:emph> </aras:emph></Requirement-Chapter><Requirement-Title aras:id="2ac08c9e494244e19f2d45269d0aa66e"><aras:emph>RiF Test item 3</aras:emph></Requirement-Title><Requirement-Number aras:id="9572d3bca90a467d9f036356ea5eb1e2"><aras:emph>REQ-000000012</aras:emph></Requirement-Number></Requirement-Info><Title aras:id="1ACDBF2AB9D74A9B89BB6175FDA7AABc" ><aras:emph xmlns="">Description</aras:emph></Title><Text aras:id="C46ABE3370A34C4C85FE33C2A28E630e"><aras:emph xmlns="">This is the description of the Requirement</aras:emph></Text></Requirement>
    2. The textual content of
    Can be inserted into the <contents> field for a re_Requirement that has been created using AML (for example) or the GUI without extra fragments.
    Until ARAS provides a better approach for programmatically generating extra content, the method may be used with caution.
