Hi Jenli,
I am not super familiar with the collab folder project. Is all the configuration just done in the xml, or was there some configuration itemtype also?
If it´s really just about the ids and if everything is specified in this xml:
I would create a fake id for your custom 'tgc_view ColumnDef' and resue this one everywhere where an 'tgc_view ColumnDef' is used (e.g. config_id, keyed_name, etc..).
All user and permission ids should be fine as long as you want to stick to the original setting.
Do you know, where the link between locked_by_id and your custom column is made?
Hi Angelalp,
I may have one more question here, I am trying to set Ascending or descending order of a column as default , made some changes in this xml file still not working. Any thoughs on this? Thanks.
-jen
Have you tried using an orderBy attribute in one of the Item tags?
e.g.:<Item type=myitem" orderBy="sort_order desc" ....>
Also I am not sure if things are so easy to solve with collab foders. Doesn´t it normally render the data as multi level structure?
