Hi Jenli,
I am not super familiar with the collab folder project. Is all the configuration just done in the xml, or was there some configuration itemtype also?
If it´s really just about the ids and if everything is specified in this xml:
I would create a fake id for your custom 'tgc_view ColumnDef' and resue this one everywhere where an 'tgc_view ColumnDef' is used (e.g. config_id, keyed_name, etc..).
All user and permission ids should be fine as long as you want to stick to the original setting.
Do you know, where the link between locked_by_id and your custom column is made?
Hi Angelalp,
As you suggested that I created a fake id and changed related ID as the same one.
Also, I found out the link between locked_by_id and column, and made some changes on it as needed, finally it is working now! Thank you! -Jen
Here is the link code below,
