Hi Jeromecha
You can use below javascript method to achieve this
var configId = document.thisItem.getProperty("config_id");
var releasedItem = new Item('Document', 'get');
releasedItem.setAttribute('select', 'major_rev');
releasedItem.setProperty('config_id', configId);
releasedItem.setProperty('is_released', '1');
releasedItem.setProperty('is_current', '1');
releasedItem = releasedItem.apply();
if(releasedItem.isError())
return;
var allElement = document.getElementsByTagName("input");
for (var i=0; i<allElement.length; i++)
var property = allElement.name;
if (property == "last_major_rev_released")
allElement.value = releasedItem.getProperty('major_rev');
Thank You
Gopikrishnan R
Hi Gopikrishnan
Thanks for your reply.
Your code doesn't answer exactly my question by was very helpfull.
The JS code to show the last major revision released is :
//aras.AlertSuccess (document.thisItem.getProperty("item_number"));
releasedItem.setProperty("item_number", document.thisItem.getProperty("item_number"));
releasedItem.setProperty("generation", "*");
releasedItem.setPropertyCondition("generation", "like");
releasedItem.setAttribute("orderBy", "generation desc");
//aras.AlertSuccess("nb" + releasedItem.getItemCount());
last_rev="";
if (releasedItem.getItemCount() > 0) {
item =releasedItem.getItemByIndex(0);
last_rev = item.getProperty("major_rev");
else {
last_rev="";
- Gopikrishnan6 years agoAccelerator II
Glad to hear that my answer provided some inputs to you.
