- angelaCatalyst IIHi Mily, what version of Aras do you use? For SP9 e.g. you can take a look at my starting page project: github.com/.../cui-select-starting-page Code for filling dropdown list: github.com/.../BPL_SelectStartingPage_onLoad.xml In my case I take the dropdown labels from a predefined 'List', but you can also fill the dropdown manually. This project will not work under SP11/SP12, as the new type-ahead function requires a different approach. I already have a SP11 compatible version of this project, but it is not online yet. Angela
- KaraCreator IThanks Angela... But i am using Aras 11 sp 12 version.
- angelaCatalyst IIThen try this one:
// Fill dropdown list in Form with available Starting Page options. Function is called on Form load. var inn = new Innovator(); // Get dropdown element from GUI var itemTypeDropdownComponent = getFieldComponentByName("Starting_Page"); // Get current start item list values var listValues = []; var itemTypeDropdownList = []; listValues = aras.getListValues("BFDEFE0CEE174B52B8972D49B446B812"); // id of List "StartingPage List" for (var i = 0; i < listValues.length; i++) { var value = aras.getItemProperty(listValues, "value"); var label = aras.getItemProperty(listValues, "label"); itemTypeDropdownList.push({label: label, value: value}); } itemTypeDropdownComponent.component.setState({ list: itemTypeDropdownList, value: '' }); return null; - KaraCreator IHi Angela, I tried above code and it is working fine. Thanks for your help. Can i write it for server method?
