Zahar_Chernov
9 years agoCreator II
Following row give you connection status:
Item loginResult = innServConn.Login();So loginResult is Aras Item... that has a function isError()... if this function return false - connection is not established. If you want to show user why it not established call function getErrorString() (of the object loginResult ) and show the result to user. About:
this.Innovator = loginResult.getInnovator();Yes - my mistake, it was supposed to be:
inn = loginResult.getInnovator();But probably you will do the same... the inn will be class property and not inside your connection function, cause you will need this object in the second function - where you query Aras for the document.
