Changing the requests in Method to AML did not work either
frank_guarino_murata_com
1 year agoCreator III
.fetchRelationships() showing outdated data
I have:
Promise () => Method => Back to Promise and perform .fetchRelatioships() of one of the items manipulated in the method.
There is still data in .fetchRelationships that should no longer be there, as Method was performing SQL deletions. I am wondering if I need to swap it to AML posts within the method, or if I am missing a way to force update AML dom.
Best Regards,
Frank
Alright so .fetchRelationsihps wasn't showing outdated data. It was showing the db data (as we should know)
Why I assumed it was, was that the passed Item variable had outdated data within its node xml
To update the node's xml, please look at my larger comment which talks of using .getItemsByXPath
Thanks
