Janet
11 months agoIdeator III
Workflow Assignment - provide 2 assignments based on property
I have a workflow map defined with several activities. And I have an itemtype "XYZ" where on the item form I have an boolean property "ABC".
Condition is, if the ABC property on the item form is check marked then the 2 activities on the workflow map should be assigned to "Engineering" identity to perform Vote Now action. If not (uncheked) then it should be assigned to the one which is defined in the workflow map assignment identity.
Please provide solution for this.
